• PathPilot®
  • PathPilot® HUB
  • Contact Us
    • Home
    • News
    • Learn
      • Learning CNC
      • How to
      • Shop talk
    • Get inspired
      • Art & jewelery
      • Automotive
      • Education
      • Gunsmithing
      • Hobby
      • Knife making
      • Medical
      • Prototyping
      • Production machining
      • Replicas & models
      • Robotics
      • Sports
      • Woodworking
    • Tormach.com
    tormach-pumpkin-featured
    Shop talk
    3 Reasons You Need a 4th Axis
    10/ 31/ 2017
    machine Mill Halloween CNC tombstone tool Workholding rotary table 4th Axis
    When buying a machine tool, it’s easy to get carried away. The excitement of purchasing a fancy new mill from Tormach makes you want to buy all the tools and accessories under the sun. Eventually, your budgeting conscience starts yelling, and you’ve got to draw a line somewhere. Often, when this line gets drawn, machine owners will skip buying a 4th axis, figuring they can do everything needed with some workholding ambition. While that might sometimes be true — though hardly worth the effort — here are three big reasons it’s valuable to consider a 4th axis.
    1: Save Steps
    Going the route of multiple workholding setups can save some money at first, but often, it becomes more work than it’s worth. If you have an odd-shaped part, you may have to create three, four, even seven setups to get your part made. Because a 4th axis isn’t only indexable but also capable of simultaneous motion, you can significantly reduce your number of setups and workholding challenges.
    2: Make Complex Curves
    Sometimes, there are parts that just can’t be done in three axes. Or rather, can’t be done practically in three axes. Read: 4 Bits of Knowledge That Separate a Beginner Machinist from a Pro For example, if you want to mill a spiral column shape or complex curve, it might be possible to cut with three axes. But the effort, time, and calculation you’d spend programming the workholding makes little economical sense. A 4th axis would make life a lot simpler.
    3: Use a Tombstone
    If you’re into making multiple parts at once, a tombstone on a 4th axis is your best friend. A tombstone acts like a fixture plate, and because you can mount it on a 4th axis, it also becomes four separate fixture plates. This minimizes tool changes and makes producing multiple parts a breeze. While these aren’t the only advantages to using a 4th axis, they’re definitely good reasons to consider giving one a try.
    … And a Bonus
    One more reason you need a 4th axis: it’s a valuable addition when you want to make a Halloween pumpkin!
    Five Things You Didn't Know About the Shear-Hog
    Interpolated Holes Not Round? Fix It!
    Quick links
    • Home
    • News
    • Get Inspired
    • Shop Talk
    • Learning CNC
    • How-To
    • Shop Tormach
    • Privacy Policy
    Recent posts
    Real People. Real Stories. - In Conversation with Kevin & Tracie Smock
    Work Hardening & Strain Hardening - A Machinist’s Guide
    What is the Difference Between Plasma Cutting, Waterjet, and Laser Cutting?
    Real People. Real Stories. - In Conversation with Corbin Dunn
    Tips for Machining Gummy Materials
      SUBSCRIBE
      Get in Touch
