• PathPilot®
  • PathPilot® HUB
  • Contact Us
    • Home
    • News
    • Learn
      • Learning CNC
      • How to
      • Shop talk
    • Get inspired
      • Art & jewelery
      • Automotive
      • Education
      • Gunsmithing
      • Hobby
      • Knife making
      • Medical
      • Prototyping
      • Production machining
      • Replicas & models
      • Robotics
      • Sports
      • Woodworking
    • Tormach.com
    andrew-johnston-2-650x555
    Tormach
    Bevel Gears from Andrew Johnston
    09/ 13/ 2011
    Get Inspired Replicas & Models PCNC 1100 prototypes Milling cut cast iron Iron machining Customer Projects finishing Aluminum 4th Axis
    Received these project photos in the inbox a few weeks back and just now getting around to posting them.  Andrew lives "across the pond" in England and is a model engineering enthusiast.  He cut out these bevel gears with his Tormach PCNC 1100.  From Andrew:
    "The bevel gears are for use in the differentials of the two 4" scale traction engines I am building. I didn't agree with the drawings I have, so I designed my own gears in Alibre. CAM programming was done in Visualmill. The gears are 6DP, the pinions are about 2" OD and the gears 6" OD. The final gears are in cast iron, but I made prototypes in aluminum to test out the design and machining strategies.
    The pinions use a roughing cut and a finishing cut, both using a 4mm three flute ball nose carbide cutter. The gears are roughed out with a 4mm cutter followed by a cleanup pass with a 3mm cutter and finally the finishing cut with a 2mm cutter. On the pinions I used the same cutting parameters for the cast iron as I used for the aluminum prototypes; 5000rpm and a feed of 400mm/min.
     By the way these gears are true bevel gears in that the tooth form scales uniformly as you move down the pitch cone. They are not the compromise that is normally used when the gears are machining using a horizontal mill and B&S involute gear cutters."
    Thanks for sharing, Andrew!
    Custom Dovetail Fixturing for the 4th Axis
    New PCNC Manual Updates Available on Tormach.com
    Quick links
    • Home
    • News
    • Get Inspired
    • Shop Talk
    • Learning CNC
    • How-To
    • Shop Tormach
    • Privacy Policy
    Recent posts
    Making Household Art with a Tormach 1300PL Plasma Table
    Prototyping Motorcycle Suspension Systems Makes Business Sense with a Tormach CNC Mill
    Pet Business Launched with a Tormach 770M CNC Mill
      SUBSCRIBE
      Get in Touch
