PCNC 1100 Series 3 Upgrade Kits now available
Series 3 Upgrades are here!
Series 3 Upgrade kits for PCNC 1100 mills are now available for sale.  The kits include 3 polyphase  motors, 3 Leadshine microstepping drivers, machine control card, and busboard.  Make sure to select the correct kit for your serial number -machines numbered 1-999 require additional mounting brackets. and should choose PN 32010.  If your mill has serial number 1000 or greater, choose PN31999.  We’ve also made the motors and drives available as a separate kit for those who want to integrate with other equipment, although those kits don’t qualify for the same pricing as the upgrade kits.
31999-series-3-upgrade-kit-for-1100-no-brackets_mg_6893
Curious about upgrade?  Remember to read our Series 3 Design Analysis here.
And another new product…
Sprung 5C Collets
Sprung 5C collets open up just a bit beyond nominal ID when uncompressed.  Why?  Because it can be really hard to load/unload bar stock when the uncompressed  collet IDs are size-on, especially if your trying to use them with automatic collet closers, etc.  Trouble is, its really hard to find affordable 5C collets that are also sprung – if you need one, you’re only options are premium choices with premium prices.
Not anymore.  We now have sprung 5C collets available for sale that don’t cost an arm an a leg.  Not premium, but good quality collets that are appropriate for the majority of home and small job shop lathe work.
5c-collets-box-of-13mg_6149
New SprutCAM Tutorials
We added 3 new tutorials for SprutCAM 7.  These are targeted at beginning users.  Enjoy!
Mouse Functions and User Interface Basics
Import/Export Basics
Introduction to the Tool Library
PS:  We’ll be at Little Machine Shop in Pasadena CA this Saturday, Oct. 15, with our new Series 3 PCNC 1100 and an ATC.  Hope to see you there!
Andrew Grevstad
Andrew Grevstad
5 thoughts on “PCNC 1100 Series 3 Upgrade Kits now available
  • Avatar
    10/11/2011 at 1:00 pm
    Permalink
    Great news on the drive upgrade.
    Sprung 5C collets, maybe that would be to fit a bar feeder on a new PCNC Lathe????????? Hmmmmmm!
  • Avatar
    10/27/2011 at 7:33 pm
    Permalink
    Will you be offering a Series 3 upgrade kit that includes the VFD spindle drive?
  • Andy G.
    10/31/2011 at 10:55 am
    Permalink
    Good question… The only advantage I see is so you could avoid the core return on two control boards, but that’s certainly an advantage. For now, I think we will handle this on as needed basis if you order both at the same time.
  • Avatar
    05/23/2012 at 2:27 am
    Permalink
    Andy, Just to say that I completed yesterday the series 3 upgrade and I am very pleased with the result. The process was straight forward with the instructions being clear and comprehensive enough.I took your advice and decided at the same time to set the Gibs on all three axis so the total time spent was aproximately 1 day.
    The difference with speed and quietness from the steppers was really very marked.Initial cuts appear to be more accurate as well. So thumbs up for a good upgrade offering.
    My regards Simon
Comments are closed.
