• PathPilot®
  • PathPilot® HUB
  • Contact Us
    • Home
    • News
    • Learn
      • Learning CNC
      • How to
      • Shop talk
    • Get inspired
      • Art & jewelery
      • Automotive
      • Education
      • Gunsmithing
      • Hobby
      • Knife making
      • Medical
      • Prototyping
      • Production machining
      • Replicas & models
      • Robotics
      • Sports
      • Woodworking
    • Tormach.com
    anatomyofanendmillhero
    Shop talk
    The Anatomy of an End Mill
    04/ 17/ 2018
    General cutting End Mill
    End mills feature many different dimensions that can be listed in a tool description. It's important to understand how each dimension can impact tool selection, and how even small choices can make all the difference when the tool is in motion.
    Flutes
    Flutes are the easiest part of the end mill to recognize. These are the deep, spiraled grooves in the tool that allow for chip formation and evacuation. Simply put, flutes are the part of the anatomy that allows the end mill to cut on its edge. end mill flutes One consideration during tool selection is flute count, something we've previously covered in depth. Generally, the lower the flute count, the larger the flute valley -- the empty space between cutting edges. This void affects tool strength, but also allows for larger chips with heavier depths of cut, which is ideal for soft or gummy materials like aluminum. When machining harder materials such as steel, tool strength becomes a larger factor, and higher flute counts are often used.
    Profile
    The profile refers to the shape of the cutting end of the tool. It's typically one of three options: square, corner radius, and ball.
    Square Profile
    Square profile tooling features flutes with sharp corners that are squared off at a 90-degree angle.
    Corner Radius
    This type of tooling breaks up a sharp corner with a radius form. This rounding helps distribute cutting forces more evenly across the corner, helping to prevent wear or chipping while prolonging functional tool life. A tool with larger radii can also be referred to as "bull nose."
    Ball Profile
    This type of tooling features flutes with no flat bottom and is rounded off at the end, creating a "ball nose" at the tip of the tool.
    Cutter Diameter
    The cutter diameter is often the first thing machinists look for when choosing a tool for a job. This dimension refers to the diameter of the theoretical circle formed by the cutting edges as the tool rotates. cutter diameter
    Shank Diameter
    The shank diameter is the width of the shank -- the non-cutting end of the tool that is held by the tool holder. It's important to note this measurement when choosing a tool to make sure that the shank is the correct size for the holder being used. Shank diameters require tight tolerances and concentricity in order to fit properly into any holder.
    Overall Length (OAL) and Length of Cut (LOC)
    Overall length (OAL) is easy to decipher, as it's simply the measurement between the two axial ends of the tool. This differs from the length of cut (LOC), which is a measurement of the functional cutting depth in the axial direction and doesn't include other parts of the tool, such as its shank.
    Overall Reach/Length Below Shank (LBS)
    An end mill's overall reach, or length below shank (LBS), is a dimension that describes the necked length of reached tools. It's measured from the start of the necked portion to the bottom of the cutting end of the tool. The neck relief allows space for chip evacuation and prevents the shank from rubbing in deep-pocket milling applications. This is illustrated in the following photo of a tool with a reduced neck. end mill neck
    Helix Angle
    The helix angle of a tool is measured by the angle formed between the centerline of the tool and a straight line tangent along the cutting edge. A higher helix angle used for finishing (45 degrees, for example) wraps around the tool faster and makes for a more aggressive cut. A lower helix angle (35 degrees) wraps slower and has a stronger cutting edge, optimized for the toughest roughing applications. helix angle A moderate helix angle of 40 degrees results in a tool able to perform basic roughing, slotting, and finishing operations with good results. Implementing a helix angle that varies slightly between flutes is a technique used to combat chatter in some high-performance tooling. A variable helix creates irregular timing between cuts, and can dampen reverberations that could otherwise lead to chatter.
    Pitch
    Pitch is the degree of radial separation between the cutting edges at a given point along the length of cut, most visible on the end of the end mill. Using a 4-flute tool with an even pitch as an example, each flute would be separated by 90 degrees. Similar to a variable helix, variable pitch tools have non-constant flute spacing, which helps break up harmonics and reduce chatter. The spacing can be minor but still able to achieve the desired effect. Using a 4-flute tool with variable pitch as an example, the flutes could be spaced at 90.5 degrees, 88.2 degrees, 90.3 degrees, and 91 degrees (totaling 360 degrees). variable pitch This article originally appeared as an In The Loupe blogpost.
    Why an Automated Bandsaw Will Save You Money
    10 Reasons I Love Tormach
    Quick links
    • Home
    • News
    • Get Inspired
    • Shop Talk
    • Learning CNC
    • How-To
    • Shop Tormach
    • Privacy Policy
    Recent posts
      SUBSCRIBE
      Get in Touch
