Tormach CNC Lathe: First Look
The Tormach Lathe….We get a lot of questions about the progress on our CNC lathe project, a ground up design for an affordable CNC lathe in the spirit of our very popular PCNC milling machines.   Its been tough not to publicly  share anything about the lathe for the last few months, but don’t interpret our tight lips as a lack of forward progress.  Things have been moving quite fast as of late…
[Not a valid template]
Threading
Gang Tooling
Wide Shot of loading the Part
It’s great to see the excitement about it from the metalworking community, and we’re committed to bringing this tool to market as soon as we can. We’re working hard on getting the details right, and there is still some way to go before this will be a product, but things are moving very fast – stay tuned!  In the meantime, here’s a sneak peek video of working hardware.  Enjoy!
Andrew Grevstad
Andrew Grevstad
30 thoughts on “Tormach CNC Lathe: First Look
  • Avatar
    05/23/2012 at 11:06 am
    Permalink
    Are you taking deposits for first orders? Will there be a beta program?
    Sign me up!
  • Avatar
    05/23/2012 at 4:35 pm
    Permalink
    I like it. I want one.
  • Avatar
    05/23/2012 at 4:57 pm
    Permalink
    I like what I see and will probably purchase one when they are in production. I have one question, will the lathe have a tailstock for supporting longer work?
  • Avatar
    05/23/2012 at 5:03 pm
    Permalink
    is their going to be a collet option 5c 16c
    Thanks Robin
  • Avatar
    05/23/2012 at 7:36 pm
    Permalink
    Now were takin’! I like the gang, but you already got all my money with my new 1100 I pick up next month 🙁
  • Avatar
    05/24/2012 at 10:56 am
    Permalink
    If it’s anywhere near the quality and capability of my PCNC1100, it’ll be perfect! I can’t wait! I desperately need this capability in my shop.
  • Andy G.
    05/24/2012 at 12:05 pm
    Permalink
    Yes, it will accomodate a tailstock. if you look closely you might see the pad where the tailstock sits in the video.
  • Avatar
    05/24/2012 at 1:20 pm
    Permalink
    “5C will be standard” – Great!!!
    What sort of swing and travels will it have?
    Do you have an approximate footprint and weight yet?
    I’m hoping it can be moved into a basement shop.
    Mike
  • Avatar
    05/25/2012 at 2:22 pm
    Permalink
    Andy, that is beautiful. Slant bed, whopping big cross-slide, 5C, tailstock-compatible (!)
    Will the headstock be compatible with water-based flood coolant?
    What spindle RPM (top end) are you aiming for?
    BTW in your next video I’d suggest not leaving the chuck key in at the end. First thing I learned about running a lathe was that the chuck key doesn’t come out of my hand until it’s out of the chuck… 🙂
    Randy
  • Andy G.
    05/30/2012 at 9:20 am
    Permalink
    Yes, spindle is water based coolant compatible. Still playing around with the Speed band, so I wont comment on that yet. Yeah, we all had a good laugh here as well about the chuck key – didn’t jump out at me when we were putting together the video:)
  • Andy G.
    05/30/2012 at 9:27 am
    Permalink
    The swing is 4″ over carriage. Footprint is very similar to the PCNC 1100, not finalized exactly yet. Same goes for the weight – the prototype you see here weighs around 1300lbs, but that is minus guarding, gang plate, etc.
  • Avatar
    05/30/2012 at 1:18 pm
    Permalink
    Sounds like this is going to be a winner. I suppose there is no chance of getting a general idea on general availability?
    Mike
  • Avatar
    06/07/2012 at 11:17 pm
    Permalink
    Wow, looks great! I love the long gang tooling table. That is a winner. So is the 5C collet.
    So…
    Do you plan to support a CNC collet chuck so that with a bar puller you can knock out short runs?
    Also, since you are threading you must have a spindle encoder. So… what about live tooling to go with that? I’m imagining bolting on a small live tool spindle per tool. Yes, it would run into some money, but for what I want to do I think I could get by with 2 or 3 pretty small spindle motors — as long as the controller could talk to them.
  • Andy G.
    06/08/2012 at 2:03 pm
    Permalink
    Re: Bar Puller. Probably wont be standard equipment, but definately plans as an add on accessory
    RE: Spindle Encoder, yes of course. I think Live tooling woudll definately be possible. Not sure yet how far we’ll go towards offering turn key live tooling, but would be really interested in what customer develop on their own
    Andy
  • Avatar
    06/08/2012 at 2:55 pm
    Permalink
    Hi Andy,
    Sure, since a CNC chuck is going to cost more, I’d make that an option and offer a bar puller to go with it — a lot of guys won’t need it. The key is making sure that there is a controller port to plug into for the guys that upgrade.
    Same on the live tooling. If I could bolt down a couple of ER20 spindle motors it would go a long way, as long as I could reach them with controller ports. Heck, 90% of what I want doesn’t require a spindle that can take side forces, if I could just drill from the side and off-center on the face I’d be a happy camper.
    -dave
  • Avatar
    06/08/2012 at 8:45 pm
    Permalink
    Could I humbly suggest, a set of soft jaws for the chuck. That way we can bore them out to take a diameter on the 1st op to hold for the second operation. Then everything runs nice and true and NO marks on the work. Regards Peter
  • Avatar
    06/13/2012 at 5:39 pm
    Permalink
    Looks great and I cant wait to see one in person. Just wondering why you chose to use a slanted bed for tooling rather than a live turret? It would be more compact, light weight and tool changes could be faster. As well setting up the future live tooling would be easier, just have a port in the head of the turret where live spindles can litterly just plug in!
    Looks great!
    Chris
  • Andy G.
    06/13/2012 at 6:01 pm
    Permalink
    Thanks. Turret is planned as an optional accessory.
  • Andy G.
    06/13/2012 at 6:03 pm
    Permalink
    Definately. We’ll be offering that option as well.
  • Avatar
    06/15/2012 at 12:40 pm
    Permalink
    I would really like to see more than 4″ of swing.
    I was hoping to use the lathe for making pulleys.
    4″ is kinda of a tinka toy size swing. To go through all that work to only have 4″ of swing kinda limits the capability’s!
  • Andy G.
    06/15/2012 at 12:55 pm
    Permalink
    Swing over bed is approximately 13″. (6.5″ from center).
  • Avatar
    06/19/2012 at 5:34 pm
    Permalink
    Andy, Make sure my name is on the list please.
  • Andy G.
    06/20/2012 at 9:11 am
    Permalink
    As soon as we have a list, I’ll announce on the blog.:)
  • Avatar
    06/26/2012 at 8:23 pm
    Permalink
    Estimated price points would be nice. That way I know how long I have to save up for one of these CNC Lathes.
    I was saving up for one of the Bolton CNC lathes but, since I already have a Tormach CNC mill, I”d much rather stick with the same brand.
    Also; the text in the video mentioned an enclosure; can you show us a prototype image of what this Lathe looks like wearing the enclosure?
  • Avatar
    10/11/2012 at 9:19 pm
    Permalink
    any updates on this yet?
  • Avatar
    10/17/2012 at 2:05 am
    Permalink
    Any new updates on the lathe? I am anxious to know, I need a cnc lathe, and have to make a decision to either wait of buy someone elses.
  • Andy G.
    10/18/2012 at 3:29 pm
    Permalink
    We just filmed an update. Hope to have it on the web shortly.
  • Avatar
    10/20/2012 at 9:13 pm
    Permalink
    Well? 🙂
    sam
Comments are closed.
